rustystud
- 2,729
- Woodinville, Washington
I installed the rear air tank I bought last year today. I installed it behind the last differential and the tow bar I installed. It's a 12" diameter by 26" long stainless steel tank I got off eBay. I plan on running the trailer brakes and rear external air line from it. I already ordered the R-14 valve. This way if I loose all air pressure I still can stop the trailer I'm towing. That is as long as I still have over 4psi pressure left to apply the R-14 valve.
Getting the clamps close enough to bolt together was a pain. I did have my "expandable Vise-Grips" but it didn't work on the left side bracket for some reason. So I had to go "old school" by using some "tie" wire and a screwdriver. Now I just have to run the new hose and install the R-14 valve when it gets here.
![002.jpg 002.jpg](https://www.steelsoldiers.com/data/attachments/442/442289-29d47e9b0e6485445423f1a5043669df.jpg)
![003.jpg 003.jpg](https://www.steelsoldiers.com/data/attachments/442/442290-f4c9c52145f5f129fe9352e8d106fb13.jpg)
![012.jpg 012.jpg](https://www.steelsoldiers.com/data/attachments/442/442291-0dec48aa4a9722a9acdc78540df8794d.jpg)
![010.jpg 010.jpg](https://www.steelsoldiers.com/data/attachments/442/442292-b4ef9184868c3539b343650f39944e65.jpg)
![006.jpg 006.jpg](https://www.steelsoldiers.com/data/attachments/442/442293-841dccadd72d5042ea69e9659b8557fa.jpg)
In picture '1' you can see the fittings on the top of the tank. The closest one is the inlet with it's one-way check valve. The other one is the feed to the R-14 valve. Both lines are 1/2" .
