erasedhammer
- 61
- 28
- Maryland
Here we go again.
So for the tire problem I had Les Schwab 'check their work' and would you look at that! They never balanced them after replacing the old tires... but that didn't fix the problem. Run flats are secure and tire is balanced.
Symptoms:
Thumping sound that increasing frequency with speed.
Sound comes from left rear tire area.
Thumping only occurs under acceleration or light braking.
In reverse there is a clicking sound like the wheel of fortune when coasting backwards.
Thumping frequency is also effected by throttle position (full throttle it has a high frequency than 1/4 throttle)
There was brown grease stains on part of the tire that looked like it drained from inside the rim. I'm thinking the geared hub is the problem, but would like confirmation before a drop money on a new one.
SECOND PROBLEM:
This may be a low fluid level (I'll be checking tomorrow) but as soon as I turn the vehicle on there's a loud hissing/whining sound coming from the master cylinder/hydrobooster area.
Sound gets louder when I turn or brake.
There is a crackling sound when the brake pedal is fully depressed.
I notice no decreased braking pressure of the pedal though. Same force required just with added annoying sounds.
Whining/crackling sound is almost as loud as the engine now.
I think the pump is going bad since loss of fluid would mean loss of brake pressure, right? And same as before I'd like to confirm before I buy a new hydrobooster.
Symptoms:
SECOND PROBLEM:
