Valleyordnance
- 0
- 6
- Phoenix, AZ
Hi guys,
I bought a 1992 M998 with the 6.2 out of Barstow for a buddy. Truck had a bad water pump on it, we swapped that out and got it running. It also needed one glow plug that we changed.
At idle the motor shakes badly, like it's "missing" on one or two cylinders. Cracked open 1 injector at a time at idle to see if the RPM's dropped, and all of the injectors seem to be firing. I had some known good injectors and swapped out the 4 on the pass side (easy to get to) to see if that made a difference, still no dice. If it was a gas motor I'd do plugs, wires and distributor. There is no smoke to speak of coming from the exhaust. Also checked & bypassed the cold advance switch (we're in AZ and its 90 degrees today)
Could this be a timing issue? I know that the timing is supposed to be done with the snap on tool. but can a guy "fake it 'til you make it"?
What else could it be?, I'm stumped!
Thanks!
Chris
Thanks!
Chris
