new lmtv owner
snowtrac nome
137
western alaska
recently purchaced an lmtv from gov plannet I will be converting it to a mobile equipment service truck for use out here in bush Alaska I will keep up on the progress.
snowtrac nome
137
western alaska
most forums do like them going down next week to pick it up and see what project I have the gov plannet pics looked pretty good inside and out. I have an a-0 unit with the 3116 engine came out of the national guard so it has real low mileage. it really looked brand new working on drawings for the tool boxes right now
TNriverjet
24
Clifton, TN
Welcome from Tennessee and another M1078 owner! There's a lot of good info and helpful folks here. You will learn lots by reading in the FMTV/LMTV forum section. Please upload some photos when you get your truck home!
snowtrac nome
137
western alaska
got the truck today put 30 miles on it runs like a top oil looks like new shifts fine once I replaced the Allison relay box under the dash Justin with gov plannet was a great help and hooked me up with a bunch of extras from a rig heading for the crusher. the one problem I cant find is when I apply the service brakes I get a leak from the vented glad hand on on the front service port if I replace the glad hand with a non vented model it locks the brakes and wont release. need to look at a schematic to follow the air system has any one seen this before.
Andyrv6av8r
455
Spartanburg,SC
Read this thread and replace your Tractor Protection valve diaphram.
http://www.steelsoldiers.com/showthread.php?144109-Air-Brake-Protection-Valve-leaking-venting
FloridaAKM
392
Gainesville, Florida
Yes, replace the Tractor Protection Diaphram first, which you will find above the rear axel bolted on the frame cross over. While you are at it, you might want to check the diaphrams in the shuttle vales to see if they are blasted thru due to age. We still want to see pictures............
roninsar
Unionville TN
New LMTV owner
Tnriverjet,
New M1078 iwner here and located south of Nashville. I would like to speak with you in some things about the LMTV. I'm not electronics savvy, so if you could email me at roninsar@gmail.com
TNriverjet
24
Clifton, TN
Email inbound sir. I'm not totally electronics savvy either. I was fortunate to find a truck where everything works... I'm guessing the learning will come as maintenance and upgrades take place.
