Pyrometer/EGT gauge: Are the K-probes all the same?
cattlerepairman
3,506
NORTH (Canada)
I have a Westach EGT gauge; worked fine for years. Then it stopped showing EGT/showed them sporadically. I put in a new K-probe. Now it does show temps, but ridiculously low (400 F) on uphill grades where it should get to 1000 or slightly above.
Are there different types of K-probes and how would one know which one is which? Perhaps the gauge itself is defective?
rustystud
3,374
Woodinville, Washington
They have different "impedances" (resistance) . You must match up the correct one for the gauge to read correctly.
cattlerepairman
3,506
NORTH (Canada)
Thanks, rusty. I found some reference here: http://thesensorconnection.com/cont...type-k-j-and-n-usa-and-international-iec-5843
However, at least to me it seems that if a probe is a certain type, e.g. a "K" probe, it should work with other "K" calibrated gauges. Time to dig up the "defective" probe from the garbage and compare impedances.....and trace the probe wires because, knowing my truck, it could be something wildly unrelated, like a rat that stepped onto a circuit breaker, flinched and nicked a probe wire.
