Hi. Got off work and rushed home to tinker a bit! The fan blades are solid, very sturdy. The belts are all tight the seem to have very little depression. I tried to wiggle fan blade bully and air compressor pulley... no play. I did have to remove and research the gasket on the primary fuel filter. I noticed that it was dripping fuel. Good news is the fuel pump in tank is working, I removed fuel cap and heard fuel being agitated. Now I think I've developed a fuel leak near the fittings by the piece next to the power steering pump. Will get into that when the sun is up tomorrow. I am really interested in switching to spin on type filters. I have a brand new racor spin on water separator filter system that is heated.... although I probably wouldn't setup the heat. I don't recall the model of the racor, but it is similar in size to the canisters of the secondary filters. The hunt goes on for the rattle at 1800rpm? I will attempt valve adjustments this weekend. Got the tm's downloaded, will search through them to find which one covers valve adjustments. Briefly looked through earlier, lots of great info and pics! Any thoughts on racor filter?
