Looked up the GM18A-TC Torque Converter he used and found and found this bit of info :
Codes: DE5F, DE8F, DEAF, DEBF,DF5F, DL5F, DL8F, DFAF
30 SPLINE (ON/OFF) NO PWM ! Paper Lining, Medium Stall (1600-1800)
12” diameter, 298mm , Pilot 1.703”, 3 Pads, 30 spline
http://www.makcotransmissionparts.com/TC-GM18A.html
http://www.makcotransmissionparts.com/4L60-700R4tc.html
Also Looking into the G134 flywheel code he used I found this:
G134 Flywheel, GM 6.2L, 6.5L diesel
Reference OEM # 14077158, Bolt pattern for a 700-R4 T/C only
http://www.makcotransmissionparts.com/FLYgm.html
http://www.makcotransmissionparts.com/G134.html
Interesting enough it matches the part number that site lists to the one referenced in this thread.
Did he use the right one after all but it was just junk then? How odd, the flexplate on it now looks identical to the one linked and that I find with the GM part number.
