- 1,172
- 24
- 38
- Clifton, TN
Ok, It's time I get a thread started to chronicle projects on the truck. This is a 1996 M1078 with about 15,400 miles when we bought it. Here is a photo pretty much as we brought it home.
This truck was one that was owned by a local TN police department and then auctioned off. I bought it from the auction winner who never titled it in AL. I had no problems getting it titled and licensed as it already had a TN title from the police department.
Pretty quickly, I realized the fan clutch was not functioning properly. There is much good information and resources here in the FMTV area to document troubleshooting and fixes. tnmogger and suprman were great resources. I ended up replacing the air solenoid behind the passenger kick panel... Works great now.
The spares I bought came off a truck with dual solenoids, so now I have a spare.
I also spent a morning greasing and checking fluids. The oil and tranny fluid appear to be very fresh with new filters. I bet the 101st ABN serviced this one before it went to the police dept! It took a tube and a half of grease to get everything lubed.
I also checked the hubs. The rears are served by the diff fluid, so I just topped it off and it looks clean and good. The fronts were kind of dry, so I added fluid and have been driving a while. The driver's side hub is a bit noisy, so I'm keeping it on close watch and am planning to tear it apart to check the bearing, planetary gears and backlash, etc. Here is a picture of the original oil drained.
This weekend I dumped it and refilled with clean oil to see what, if any shavings were in there. I was pretty pleased with the results. It has quieted down some, but is still not perfect. I hope I don't have a wheel bearing trying to implode, but we will see...
