TNriverjet's M1078 Thread
TNriverjet
24
Clifton, TN
I took my wife and son to the river for a shake down run the next day. M-1078 hauls the 15.5 ft canoe with ease. [thumbzup]
TNriverjet
24
Clifton, TN
Keep us posted if that air dryer fixed your issue.
So far, it is much better. There is no moisture purging from the tanks when I open the drain valves. We haven't had cold enough weather to find out if the brakes freeze, but I'm 95% sure the problem is fixed. I was getting water out the purge valves all the time with the finned tube version of the air dryer. Now it is dry coming out for sure.
snowtrac nome
140
western alaska
the reason why the fittings didn't match, is air brake fittings are different sizes than plumbing fittings for copper pipe. You should have gone to napa they would have sold you the right fitting no messing around
TNriverjet
24
Clifton, TN
Yes, I went there, but my local NAPA had a mess for their air fitting parts storage. They even let me back there to rummage. I spent 30 min and could not find anything to work. I finally found the right combination of hardware and got it all hooked up.
321
14
Montana
Thanks for posting this, I would love to know more about the shims, maybe a PM with a link to the source, also any info on how to shim correctly, hub disassembly looks easy enough, just need to know how to choose correct shims if posable, mine are a tad noisy too, thanks sooo much
Seth
I have been thinking about the noisy drivers hub and bought a shim kit off thebay for $13. I decided to tackle hub removal today and check things out. Photos loaded in reverse order of disassembly. Sorry.
View attachment 659166View attachment 659165View attachment 659164
Check out the wear/gear mesh pattern on the spiders
It seemed to me they were not engaging the full tooth face. Shimmed.
There was also a slight bit of rust on the old shims and one of the teeth on the inner gear. I cleaned that up and re-installed everything. No leaks and much quieter in test drive.
View attachment 659168View attachment 659170View attachment 659169
TNriverjet
24
Clifton, TN
