MrSEE
- 0
- 6
- Billings, MT
Hi guys,
Very strange issue I've been chasing for awhile now. I won't try to influence how you see it, but I will say I've tried about everything. Here are the symptoms and what I've done so far.
Machine starts very well and runs well. Voltmeter pegs under 24v before start and until running, where it stays around 25-26v while messing about
At lower temps (sub-20 degrees F?) it will not show power on the gauges or power up the starter.
Battery switch is good-- continuity test with cab off
batteries are brand new, but regardless provide 25.7v
Ignition switch is good-- I've replaced from a functional unit and tested/compared
Battery cables checked. Fine. Grounds good on frame behind battery box, but we cleaned and tightened those as well. Also checked and cleaned the positive cable and traced up to starter
5 24v relays all new on relay panel under headlight switch.
I clean nearly all contacts manually on these as a matter of procedure. Fuse panel has been cleaned/brushed and all new fuses
No chewed wires under dash and two under-dash/behind gauge grounds are clean and tight
Alternator has been tested and is excellent. Brushes full.
I've bypassed the DCE/IC shunt... tried with and without this in circuit.
I've replaced the 24v/50 amp fuse under the alternator from a functioning unit. No change. I've also opened this unit's relay and there are no signs of damage.
The machine has power and starts very well if it sits in shop for a couple hours and gets warm. Cold (sub-20 degree?) makes nothing work. No juice. I've tried batteries, charging system, relays, and major grounds. What the **** is going on?
Thanks.
Thanks.
