Just picked up my first M925A2 with the Cummins 8.3 today. It is a 2012 rebuild with less than 400 miles so it does not seem to have much of any wear on the main components. I have some mods I would like to do to it like adding a 2 1/2 receiver (possibly the Curt one I currently have on my M35A2) and auxiliary hydraulics to run a live bottom pull-type trailer.
I read thru several pages of posts about adding auxiliary hydraulics on the existing hydraulic system but did not notice much detail as far as photos or what parts I would be looking for. I hear the hydraulic pump on the M939's can produce a lot more gpm/psi then they are rated for but the control valve, relief valve and reservoir size limit this. I could possibly change any of these out with components that will give me more capacity if needed. I am looking to "T" in someplace after the hydraulic pump and add 1 pressure line to run the trailers single hydraulic motor and as 1 more line as a return to the reservoir. Any ideas or details from someone who has successfully done this already?
