bebyb
- 0
- 6
- Old Hickory, TN
Hello all, quick question. A few months ago I discovered just in the nick of time that the previous owner of my truck had put straight water in the radiator. So I drained it out and replaced it. So I started it up and idled it for about 10-15 minutes and the coolant I could see through the filler cap was just stagnant. This got my cencerned that maybe the water pump impeller was messed up, but the lines going directly into the water pump seemed like they were getting warm, but I don't know if that is warmth from being that close to the engine. My temperature gauge is down and i am going to replace it soon, but I can't use the temperature gauge as a reference because of that. Well anyway, a little while later I took it on a long trip from Nashville, TN to East TN, and through the 3 and a half hour drive it continued to purr like a kitten, didn't show any signs of overheating, even going over some of the grades on I40. However, does this sound like a water pump issues or is everything normal? It isn't the overheating I am worried about but I just want to make sure the antifreeze got circulated through the block like it was supposed to, because it got down to 8 degrees about 2 weeks ago.
Thanks
Thanks
