- 326
- 91
- 28
Yesterday was a good day up here in New York, I had plans to go out a change my fuel and air filter and to see if my fuel pick up / transfer pump sitting on top of the fuel tank was working on account i could not here it the other day. as I had just purchased this vehicle last weekend. I was able to do so. first i changed out the air filter with the correct 400 cfm air filter as required. then it was climbing under the truck to start the replacements of the fuel filters.I removed the primary that had been changed over to a spin on, filter was showing signs of rust having been in there for the period. as i moved to the secondary and tertiary filter this showed me how well maintained the fuel filters had been maintained. these filters were of the stock type. my first attempt was to drain some of the fuel from both but no fuel was to be drained. so i then removed the top nut securing the fuel filter to it housing, and lowered it into the bucket under it. dumped the fuel and pulled out the filter yikes, looking inside the empty canister was about 1" of mud. with that canister marked I removed the third and that one was not as bad,maybe 3/4 1/2 " of mud. I then removed all the scale and mud build up from inside the canisters ,also removing the drain valves and cleaning them removing the build up from inside.I then installed the filters into the canisters.the gaskets that came with the fuel filters i placed around the canister and hit it with some heat from a blow dryer,I found them to be a little on the smaller side before stretching them with the us of heat. I then coated the gaskets with grease and placed them in there grove followed by each filter being installed an secured.I then had my son listen for the fuel transfer pump,no sound but the sound of fuel coming out from the drains on the second and third fuel canisters.once tightened there was no more signs of fuel leaking. I then opened the bleeder valve on the top of the fuel filter housing and bleed out the air. so now I know the fuel pick up pump is working my filters are clean along with my air filter.
