M151A2 fuel pumps - commercial replacement?
tokarev
Safety Harbor Florida
[FONT=&quot]The question is are there A2 fuel pump rebuild parts or whole pump commercial replacements available ? I've been away from the Mutt parts scene for a few years now...Thanks[/FONT]
m38inmaine
102
Maine USA
Dodge slant six from mid 60's if I recall, it won't have the fording vent but a direct fit.
M151Bernie
Germany
Hi,
I installed an electrical fuel-pump from Hardi (14424, 24V) into my A2. Not sure if this is the best solution though, I'll find out in coming season...
Bernie
snowtrac nome
140
western alaska
The engine is a hurclees, they were used in cat and Daewoo forlift trucks, just find a Daewoo forklift dealer he can get you a fuel pump for a Daewoo g -25 with hurculees engine your local cat lift truck dealer can likely get you one to.
snowtrac nome
140
western alaska
I would to, but for those that might need one down the road I posted the info as to where parts for these engines are still available. The only things I found different is flywheels starters and fuel and air induction system the forklifts don't use the side draft zenith carb or manifold. The distributors are different to but if one was to do a 12 v conversion than and use commercial wires and plugs those engines would have the parts to do it.
nc715
Kernersville, NC
I just used the pump that fits the MoPar engine. No vent, but easy enough to add. Remember the NOS pumps are 30 years old and the rubber probably will not stand up to ethanol fuel.
