Zoidsfan77
- 1
- 6
- Columbus, Ohio
Engine Locked Up? | 855 Cummins
Greetings! Sad times hath befallen.
Today I went to start my M814 with the NHC 250 Cummins. It turned over, and began to start. It spat a good deal of white smoke, but not anything to out of the ordinary for this truck. I felt the engine was running, and disengaged the starter. About one or two seconds later, the engine just stops. Not the usual coast down to a stop, it stopped immediately. I waited a minute, then hit the starter again, nothing. Would not budge.
So, I opened the hood, removed all the rocker covers, and barred the engine over by hand to see if I could find anything really suspect. It actually turns pretty freely, except for one hard spot.
As some of you may recall, I just did the overhead on this truck, and although it did run and drive since, it was only once, just after I finished. The truck has sat for some time since, a week perhaps.
That thread is here: http://www.steelsoldiers.com/showthread.php?163532-To-Purge-or-Not-to-Purge-855-Cummins
So I am kind of bummed out. I really hope it didn't hydrolock and bend a connecting rod. Best case I guess is that I set the overhead wrong, and an injector is damaged.
But I did drive it once since setting the overhead, and it drove about the same as before (low power).
Those of you with experience, what would you do next?
