86m1028
- 17
- 38
- Murphy TEXAS
Again, thank you for mentioning this as a possibility.a good point has been made there is a cover on the front acc drive cover screw it off, on your truck you should have a tach drive on it with an inspection mirror check and see if the nut spins with the gear. the gear mounts to the pump with a taper it takes about 130 ft pounds to torque the nut on the end of the pump. The p7100 pump is known for coming loose and loosing timing especially if the pump is pushing a lot of volume. if some one changed the pump and didn't torque it right it may have lost time or come loose, yes I have seen this before.
EDIT: I did just confirm tach does register about 200rpms when cranking,
have not checked with either yet (need to go get some).
