Rmtaunton
- 31
- 48
- Smyrna, ga
I bought one of those (without the box). I think that is a double acting valve, forward and reverse.Really jealous now.
Just found out this morning that my crane won't unload the T-case in a can that GL put in the bed for me. The winch will pick it up fine but the brake won't hold it. Looks like I'll have to remove the 30~ bolts and unload the top and bottom separately. Sigh...I just put those bolts back in and sealed it back up.
I did pick up those 24v hydraulic power packs. I have yet to spec them out to see if they'll run a crane though. If they will, then the box will be mounted in the spare tire rack. Given all the wires and what I think are a couple of coils on the valves, I think they will run multiple functions. Not to fluent on fancy hydraulics so will leave that to the expert to figure it out.
It's not that bad at least you have all the wiring I had to figure mine out 12 volt solenoids 24v solenoids 24v pump all working together without backfeeding the 12v stuff , call me anytime if you got questions now to set the flow rates and pressuresReally jealous now.
