Auto crane 5005h on 925
Another Ahab
4,555
Alexandria, VA
That's a right solid pedestal, and that tube steel in the frame looks serious; is that 1/2" wall?
I wonder what that stuff weighs per foot; like 10-12 lbs?
Rmtaunton
31
Smyrna, ga
There are two 5x5x3/8 main tubes and lots of 3/8 Chanel one is 30 " long in the crane side horizontal it will be welded to a 1/4 plate 30x12 with 8 3/4 grade 8 through the frame , the passenger side will have 4 bolts through the 3/8 x 3 angle
Rmtaunton
31
Smyrna, ga
Well got Bubbles back from camp house all welding is done for the frame. Now just getting parts for the new hydraulics and need to build a pedestal for the boom , and order cylinder for the outrigger
Rmtaunton
31
Smyrna, ga
I was thinking of splitting the auto and crane part black and green , it will say auto crane one way or another
Another Ahab
4,555
Alexandria, VA
That rig will get some work done; sweet. :jumpin:[thumbzup]
For a minute there I thought you also had a scissors lift on the bed, but I see it's just a low riding trailer.
Nice set up!
Swamp Donkey
The Engineer
120
Gray, GA
Really jealous now.
Just found out this morning that my crane won't unload the T-case in a can that GL put in the bed for me. The winch will pick it up fine but the brake won't hold it. Looks like I'll have to remove the 30~ bolts and unload the top and bottom separately. Sigh...I just put those bolts back in and sealed it back up.
I did pick up those 24v hydraulic power packs. I have yet to spec them out to see if they'll run a crane though. If they will, then the box will be mounted in the spare tire rack. Given all the wires and what I think are a couple of coils on the valves, I think they will run multiple functions. Not to fluent on fancy hydraulics so will leave that to the expert to figure it out. :mrgreen:
tobyS
833
IN
Really jealous now.
I bought one of those (without the box). I think that is a double acting valve, forward and reverse.
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
Wired pendant or wireless? What did you find out on the solenoid voltage? Lookin good man!
I agree, we need video
Rmtaunton
31
Smyrna, ga
Really jealous now.
It's not that bad at least you have all the wiring I had to figure mine out 12 volt solenoids 24v solenoids 24v pump all working together without backfeeding the 12v stuff , call me anytime if you got questions now to set the flow rates and pressures
