Jericho
- 71
- 48
- Landaff NH
Gents, Ladies.
Have a shake and back and fourth shimmy in the front of my 931 A2 , starts about 40 ish , goes away most of the time by 50 /55 makes the steering feel really "LIGHT" , no doubt likely one of three things?
1, bad wheel bearing , HUM.
2, alignment, UMM ,
3. or unbalanced tire ,short of pressure type thing and cold temp wheel set ( This condition usually goes away after proper inflation and driving enough to "round " the tire back out .)
inflated to 70 psi , still there . If it were a lifted WJ I would look at the tie rod ends
Thinking ill start with the easiest , have iron bar ed the wheel, cant feel any real movement .
Being a rather large wheel balancing is out of the question,
HAS ANY ONE TRIED CLOCKING THE WHEEL TO SHIFT THE BALANCE AROUND THE CIRCUMFRENCE AND POSSIBLY OBTAIN A BETTER BALANCE ? or have any further insight, have been thru the limited trouble shooting in the T.O. Thanks for you kind attention
2, alignment, UMM ,
