Navy GiJoe
- 0
- 1
- Fort Worth TX
Like many other MEP-831A owners, I have found that the Convenience Plug is not very convenient, the GFCI is only 10A. After looking around this site and reading lots of threads, I decided to replace mine with a similar GFCI from the same manufacturer, but rated at 20A. The new unit does not have a manual reset for a thermo overload, but I can live with that. I found the part for sale on line for under $60, and it only took about 30 minutes to swap out including taking the pictures. If you can wire an outlet, you can do this as well. There are only 5 wires involved. Easy Day.
Picture of the original unit outside
Original unit from inside
The two units side by side
The new unit outside
The new unit inside
View attachment GFCI Panel Mounts Product Datasheet.pdf
The new unit inside
