Alternative fuels in modern engines
SimplexCoda
Ruidoso, New Mexico
Hello,
I will start out by saying a couple of things. First, I attempted a search for this info, but found nothing. Admittedly, my search skillz are not too great. Secondly, I do not currently own, or plan on buying in the near future, a modern diesel. This question is simply out of curiosity and so that I have more information. Our good friend Joe once said "Knowing is half the battle."
So, here the question. When looking at alternative fuels (read: JP-8, WMO, Bio, WVO, SVO, Etc.), are there any that are usable in new diesel engines? Meaning, are there any fuels, or combinations of fuels, that will work in cummins, powerstroke, duramax or ecodiesels that use DEF?
I understand that JP-8 has less lubrication built in than street diesel. But, if one were to add, say, WMO to it, would it work out? I'm particularly interested in understanding if it's possible in 2010 and newer cummins, duramax, and ecodiesels. Like I say, I don't own one now, and wont in the near future, but if I had last year's vehicle purchase to do over, I would buy one of those vehicles. Also, if I were to end up with one, at some point, I would not run it regularly. It would just be good info to have. Then I would know that, should I ever have to resort to it, an FMTV (which I do plan to buy at some point when I can) COULD be run off of similar alternative fuels. But, also, that once I get an FMTV, I would be interested in swapping to a diesel daily driver just for fuel compatibility anyway.
Thanks for the answers, and if this has been answered before, please kindly point me in the direction.
Barrman
2,244
Giddings, Texas
Disclaimer to start with. I do not work on the newer electronic common rail diesels. So I have not seen first hand what happens to them with non diesel run.
I do talk vehicles with just about everyone I actually talk to. The 6.4 and 6.7 Ford engines don't run right and have lasting severe valve and fuel system issues when the old standby of adding a quart of atf to a tank of fuel. The Cummins has injector issues which leads to DPF and regenerative burn problems when anything besides diesel is used. Both of the above came from Ford techs or repair shops that do only diesel work.
At current prices I don't think it is worth the risk/cost of running anything besides diesel. Then there is the legal side of it. Lots of states have enacted laws to make sure they get every tax dollar they can from on road fuel. If you get your tank dipped and anything besides clean green diesel is found. What will that cost you?
sorry my reply is low on facts. I have been down the wmo path before and total time plus money involved has convinced me what you get at the pump is a good deal in the long run.
fsearls92
157
Charleston, SC
If you want a Multifuel engine to run on a variety of fuels, you should look at either the m44 series or m39 series trucks. They will run on a variety of blends (as long as it's clean and will lube the ip). It's better to just run straight diesel in Diesel engines (my opinion). Also, I have a house in Alto, NM so good luck from a part time neighbor.
SimplexCoda
Ruidoso, New Mexico
You have a home nearby, eh? Would be neat to get to meet someone who knows something about these vehicles in person sometime.
I'm not really looking for a multi fuel truck. I had thought about it, but I would get the m35 if I ended up there. What I really want is the m1087 for a conversion. But, I know it can also run on several different jet fuels, etc. So, it was mostly out of curiosity that I was wondering if an engine such, what I believe people are talking about when they say "common rail diesel" (forgive me, I know nothing about diesels right now. I've got pretty good experience with Chevy's gas engines though.) would run on some other fuel, or mixtures of fuels if there were ever a need to do so. It certainly wouldn't be something to do on the regular. I understand there were some consumer engines that would do it a while back. But, who wants to drive an 80s Ford for "just in case?" not me.
Sent from my HTC6545LVW using Tapatalk
iatractor
19
SE Iowa
A local biodiesel plant put their first official batch in a Jeep liberty diesel B100. Didn't make it out of the parking lot. While the specs pass as #2 diesel, many of these modern diesel engines have viscosity sensors/fuel burn sensors that can tell when something other than #2 is being used. I think most of the engines within the last 10 years accept up to a B20 blend. Seems like there is some tweeking/computer reprograming that must take place on the engines to run JP8 in extreme cold climate conditions.
SimplexCoda
Ruidoso, New Mexico
So, in other words, engine makers are becoming more strict about what you can run. I guess it makes sense. I'm thinking of the Ram 3.0 Ecodiesel. When you look at the Ram 1500 HFE, everything about that truck was designed for one purpose. To be a full-size pickup getting upwards of 25 mpg with a diesel engine. From what I have read, they managed that and then some. But, it's all designed to work in a very specific way. So, it makes sense that they don't want it to run on something other than it's designed for. I think that liberty the plant used has the 3.0. Oddly enough, I literally just found a post on another forum that says that the owner's manual says it can run up to B20. But, they also cite a possible reason higher viscosity of fuel won't work is because of low ring tension. They seem to believe that the fuel seeps past the rings and into the oil. It seems like modern engines of all types have issues with low ring tension.
doghead
4 Star General /Moderator
1,193
Short answer is no.
snowtrac nome
142
western alaska
the electronic engines tend to be more forgiving about lubricity. how ever the emissions systems are very unforgiving and expensive. I would recommend ulsd only the other thing you have to consider is stability under pressure, the new systems are seeing up to 44k psi and ulsd will crack at those pressures, and return tar to your tank. I can only imagine what may happen over time with wmo or vegetable oil
JonMolander
Alamogordo, NM
Cummins allows up to 5% blend of oil for the purposes of improving lubricity. If you can filter your WMO to 2-micron or better and can meet several other factors (for example Cummins Service Bulletin 3379001), then go for it. However, expect a quicker attrition of fuel filters, SCR, and injector nozzles.
BTW, I'm moving to Alamogordo in a month. Hit me up. I'll be driving my M35A2 from Ohio.
SimplexCoda
Ruidoso, New Mexico
Yeah, basically I am finding that due to a combination of things, it's not really advisable in common rail engines. However, they do almost all advertise the ability to use up to a B20 blend. Although, in practice, that remains to be seen. As someone on a different forum put it regarding the Ecodiesel: "Considering they were trying to making something more 'green', they really only succeded in acheiving better fuel economy." So, in other words, it's still not "green" since you can't really use any form of recycled fuels.
When you get to the area, you should let me know. It would be cool to meet up and learn a bit more about all this.
Beyond Biodiesel
37
Prescott, AZ
I run an alternative fuels forum, and there have been a few people on that forum who claim that they have successfully run blends of WVO and gasoline on common rail engines. Otherwise we have lots of people claiming success on a wide range of older diesel engines. The Ford 7.3 PSD is famous now for burning almost anything.
Things to keep in mind when burning waste oils in diesel engines:
1) WMO and WVO will make glue in your fuel system, so it is one or the other, but not both or successively.
2) WVO blends, and SVO systems both have a blowby problem of allowing unmodified vegetable oil to enter the crankcase. There, high melting point triglycerides, and gum, precipitate out and hang up on the rings, valves, and oil cooler gumming them badly leading to premature cylinder wear in as little as 20,000 miles of driving.
3) A turbo charger greatly extends the time before engine failure.
4) WMO needs to be run through a centrifuge, because the carbon particles in it are too small to come out in any filter.
iatractor
19
SE Iowa
One thing I might add about the waste engine oil is that the quality and consistency can vary widely from supply to supply, and then it may even vary on quality each time from the same supplier. Seems like places that have a used oil storage tank tend to have many products dumped in them-antifreeze, gear oils, mystery products, gasoline, diesel, and whatever else that is liquid.
SimplexCoda
Ruidoso, New Mexico
This is all really neat information. I'm just very surprised that companies want to "go green" but are making it increasingly difficult to use alternative fuels. My guess is people are in bed with oil companies.
Sent from my XT1565 using Tapatalk
red
26
Eagle Mountain/Utah
Been reading up on a bunch of peer reviewed articles about biodiesel, in particular with common rail engines. When the biodiesel is from a category 1 or 3 source (typical plants are source 1, source 3 is algae) the common rail engines run fine over extended testing. The biodiesel from category 2 sources (WVO) is problematic.
Emission system programming has problems with what is coming out of the engine. The cleaner exhaust is outside of it's parameters and the computer doesn't know how to react.
Beyond Biodiesel
37
Prescott, AZ
It seems reasonable to me to consider that those who invest in petroleum are likely to invest in automobile manufacturing; to the point that they would influence the auto-maker to make sure their engines only run on petroleum distillates, and not on alternative fuels.
Special T
21
Wetside/ WA
One of the big advances in alternative fuels is propane. Several municipalities here in Washington State, specifically Anacortes is using multiple propane injection in gas motors. Apparently they work excellent in the Ford V10 in bigger work trucks like the F550. Most kits reflash or replace the 2nd ECU meant for E85 fuel to change the injection and other programming.
SimplexCoda
Ruidoso, New Mexico
I know lots of people used to use propane in a diesel in the same way nitro would work in a gas engine. I also knew of people who converted gas engines to propane only. It turned out to be terribly inefficient, so they ditched that idea.
Special T
21
Wetside/ WA
I've heard the direct injection system is much better than the old propane mixer going over the top of the carb or replacing it. Essentially your truck ends up with 2 sets of injectors for each cylinder. One for gas one for propane.
