Good morning and Happy Easter,
Yesterday, I took my HMMWV to a designer for some ideas on what to do with it. I have driven it about 1000 miles since I got it. It had a small power steering fluid issue in the past that is fixed. While I was at the designer I noticed a drip on the drivers side wheel from the geared hub. I went a few more miles to my office. Then I took it home. It leaked a good deal more (I would say twenty or thirty drops.) My son and I cleaned the area and we feel like it is leaking from COVER,STEERING ARM ( 18 ). We are wanting to fix the problem. The TM-9-2320-280-20-2 says to tighten to 65 lb-ft.
1. So I thought I would check to see if the capscrews on the steering arm cover are not tight enough. If they are not I would taken them out one by one and add thread lock and reinstall and tighten them to 65 lb. Drain and Refill (1 pint) hub with new GO 80/90 (Gear Oil).
if that did not work
2. I would disassemble to take the Steering Arm Cover off. Clean the cover and add Anaerobic Gasket Maker then reassemble. Drain and Refill (1 pint) hub with new GO 80/90 (Gear Oil). Test and see if that works
if that is not it
3. I would bring out and endoscopic camera and see if I can find the leak somewhere else.
If you have any advice or helpful experiences I would love to hear it.
Thanks,
Jeff
if that is not it
Thanks,
Jeff
