expeditionnw
- 1
- 18
- Alaska
Working on a new to me 1998 m1078.
Have analyzed the TMs this evening till my eyes bled.
A little background on truck. Was a basket case. Air system missing key components, lots of stuff disconnected at the fuse panel. Missing all fuses and relays, missing turbo, fuel filter housing, voltage regulator. And fluids were drained.
Also missing start inhibit switch.
Got it pretty well reassembled now.
Issue is, it wont start when pressing start button. The starter is turning, just engages and disengages rapidly like the batteries are low. Can jump the starter relay pins at fuse panel and starter will turn normally.
Engine starts right up when jumped from the starter solenoid on frame, and clipwire to fuel shutoff.
Engine also starts right up when jumping starter relay in fuse panel (with clipwire on fuel solinoid)
So my cranking issue is between the start relay and my start switch.
I believe my fuel shutoff isnt getting power because my missing start inhibit switch. Checked TM tonight, The wires that go to it are lugs TL159 and TL158. I will connect those together and im sure will resolve that issue.
I Confirmed my fuse panel is in order, all relays present and in the right spots. panel wiring is clean, no corrosion, everything looks new and shiny.
Batteries are charged.
I Tested solenoid, its good. Can jump it both ways to start. even put a ground to it thinking maybe a spotty thermo switch. nope.
I also bypassed the oil pressure safety switch, it is working correctly.
Trans controller is lit up showing neutral. mode light engages when button is pressed. Wont change to D or R though. stuck in neutral.
I believe this is a Wtec3, as it has the RED display controller, and no black Allison box under the kick panel. has a aluminum 3 plug module under there.
What obvious thing am I missing here guys?
