- 1,813
- 1,519
- Orlando, FL
I'm going to be swapping out the engine in my M1078, because of the cracked block. The replacement engine is good, but also out of a mid-'90s truck. Is there anything I should go ahead and work on or replace, on the new engine, while it's out of the truck and easy to access? Seems like it might be a good time to replace some gaskets seals that go bad with age, like the rear main seal on the crankshaft, or similar.
Any advice?
Any advice?
