- 326
- 91
- 28
When adjusting the valves, do you need to remove the fuel injectors in order to turn over the engine with the Transfer in neutral,the trans in 5th and long pry bar in the jackshaft.what im not finding in the TM's is do I need to remove the fuel Injectors as I know the spark plugs are removed on a internal combustion engine allowing you to roll her over easy.. all the TM I looked at donot mention this. Also what was mentioned in one of the post is to turn the engine over with a large pry bar in the jackshaft , where is the jackshaft. thanks
