erasedhammer
- 60
- 28
- Maryland
CZSU
0938
3276
read directly off the EPROM chip.
Was in a box with a Serv. No 16196390
0938
3276
My transmission is all sorts of ****ed up confusion right now. I'm trying to determine what vehicle/engine this eprom was for. I found that sheet that had a couple numbers and corresponding engines on it, but this number was nowhere on it.A little confused. Are you asking what an E-prom is ? It's the "chip" that goes in the ECU for the engine. E - means it's flash programmable (can be changed by someone with the equipment and know-how).
No, this is the program chip in the transmission computer. We don't have an engine computer in our HMMWVs unless a non-military swap had been done. I saved an extended list of EPROM chip numbers on my desktop. I'll try and find it and give you an engine/trans combo for this chip. I'm also wondering if you have the correct torque converter, as that could really mess with what the TISS is reading and thus, your shift points. When you're limping in first gear, do you have to get to a rather high RPM to start rolling/feels like slippage?From what I can find the chip is for the engine computer. This shouldn't have any bearing on your transmission if the engine is operating properly. A little more info if you could :
What, exactly, is wrong ? You asked about an engine chip then mention a transmission problem. Diagnoses are based on facts. If all you wanted to know is what the chip is for, then you have your answer. Glad to help but need to know what the question is before a suitable answer can be provided.
Thats very interesting as I took that EPROM chip out of a Transmission Control Module for the 4l80e...From what I can find the chip is for the engine computer. This shouldn't have any bearing on your transmission if the engine is operating properly. A little more info if you could :
Definitely is the correct torque converter, came with the transmission. I disconnected power from the TCM to see what true limp mode felt like. Its definitely starting out in 1st gear, cause 2nd gear is a lot more sluggish.No, this is the program chip in the transmission computer. We don't have an engine computer in our HMMWVs unless a non-military swap had been done. I saved an extended list of EPROM chip numbers on my desktop. I'll try and find it and give you an engine/trans combo for this chip. I'm also wondering if you have the correct torque converter, as that could really mess with what the TISS is reading and thus, your shift points. When you're limping in first gear, do you have to get to a rather high RPM to start rolling/feels like slippage?
94 6.2? That's interesting considering the TCM box has the number for a m1114... I got the tranny and tcm together from predator. I'm near the end of this 4l80 change and its brought more trouble than I thought it would.From what I can find the chip is for the engine computer. This shouldn't have any bearing on your transmission if the engine is operating properly. A little more info if you could :
CZSU Is for a 01 6.5 NA truckCZSU
0938
3276
Well that makes me feel a little better.CZSU Is for a 01 6.5 NA truck
16196390 is just a standard 12v trans computer.
There is another brand computer used in these trucks...PCS Tcm2100ba
Do you have a sheet to cross reference the numbers and the truck engine combo?CZSU Is for a 01 6.5 NA truck
Found this on epay: TCM2100AACZSU Is for a 01 6.5 NA truck
Okay, will consolidate in the future.You have started at least 7 new threads on this transmission swap and problems.
Stop making new threads~!
Nobody wants to search your posted threads to make sense of your issues.
Posting a new thread with a few numbers and no questions, is not the way to get help. It just confuses others and clutters up the forums.
I'm not going to take the time to make sense of your other 6 threads and merge them in an order that would be understandable, so please just continue one of your existing threads the next time you need help with this transmission project.
