riderdan
- 20
- 18
- Central Kansas
I looked the the TM and didn't see an obvious answer...
The volt gauge is in the yellow when running and battery voltage shows 25 at the battery terminals. I was expecting 28v if the alt was charging. The old "hold a small piece of metal on the back to check field strength" thing didn't work. The little cover (over the pos connection) says not to remove w/o disconnecting battery. I suspect a bad regulator, and was hoping there's an easy way to check voltage at the alt.
