Leaving For Findlay 1970 M813 Metal Strips in The Transfer Case
64
Evansville, IN
Hello, my friend and I were working on the 1970 M813 truck getting it ready for an around 800 mile round trip to Findlay later this week. We drained the transfer case and the fluid was very dark and nasty. Attached to the magnetic plug there were these strips of metal. I could reach in the drain hole and pull the rest of this out as it was laying in the bottom. Using the flash light everything looks clean and the gears appear to be in good shape, but obviously I can only see 10-20% of what is in there from that drain hole. The transfer case appears to shift fine and I commonly split shift with it. Does anyone know what part this is and most importantly if this were your truck would you run it forever, or pull and replace? In the first picture I put in a circle as it might have originally been a ring but I know literally zero about these units. Thanks
Evansville, IN
Not what I wanted to hear but that is the way I was leaning anyways. So it looks like I will me making the trip in the Super Duty. In regards to the transfer case, do you guys recommend having it rebuilt locally, or trying to source a new or rebuilt one? Can they be "split" and easily serviced on the truck? If it has to be lowered and replaced I am not comfortable doing that with the jacks that I have and would likely be crushed to death! So I would consider taking to a truck transmission shop and paying to have it done.
1,144
It looks like park of a cage on a roller bearing . I wouldn't take a 800 mile trip with that coming out of the transfer case.
ditto
If you can find a remanunfactured unit in the can or an NOS one, by all means that's the way to fly. You do run some risk with units like that, if they haven't been properly stored, they could have corrosion internally. It's just something to consider.
I assume it's just a larger version of the 2.5 ton case, albeit with a different front axle engagement system. Look at the tech manual and anyone who's competent at building gearboxes should be able to service it.
You will need to remove it from the vehicle and split it.
gimpyrobb
dumpsterlandingfromorbit!
27,787
777
Cincy Ohio
Honestly I'd take this opportunity to swap in a T-case from a 939 series truck. You'll get overdrive in high range AND get an airshift instead of the sprague.
zebedee
conceptualizer at large
894
Central NY
.......... So it looks like I will me making the trip in the Super Duty...............
Sorry to hear about the hick-up to your plans.
I'm thinking you and the previous owner "your friend" will be very comfy in the Superduty. I hope he doesn't snore too much.
[I think I'm making a reasonable assumption here considering the vehicle and your location!!!]
Re pieces - yes it's a roller cage, but why aren't there any ball bearings in the oil? (you did check the oil right?)
.... Balls are probably still in place, held in the races, but they will start to bunch not being separated uniformly by the cage - this will stress the races and ultimately - failure altogether.
I wouldn't risk the trip 'as is'.
Looks like the cage pieces could be rebuilt - a la crash reconstruction on a hangar floor and thereby I D it's size and hence location...
Shirehorse
26
Mantua, OH
.... Balls are probably still in place.
Howard,
Your assumption is correct. Also, you are the expert on balls, so I will go with your advice that they're still intact. :wink:
Those were the only pieces in the oil. No other parts of a race, or anything else. I'm glad we caught it now, instead of on the road.
Looking forward to seeing you at Findlay.
~Brian
74M35A2
340
Livonia, MI
So, what did you bring down? Cletus and the F-Series? I would have drove that 8-ball, no prob. It's not an airplane engine, it is only 47 years old, what's the worst that could happen? You make some new friends.
Good to see you there. Sorry it rained and everybody took their toys and went home.
