m931 solenoid problem
allie
17
equinunk pa
i believe i have a solenoid issue my 1986 m931 tractor wont shut down using switch i have to use emergency shut off then open hood and push cable back any help would be appreciated i wanna get it done before memorial day since it'll be in the parade thanks!!
redrustyhill
scobey montana
anybody have a fuel shutoff solenoid for a 1986 m931 tractor?
For a quick fix you could get a cable stop from your local parts store and put it on the push side of the emergency stop cable, that way it will reset when you push the cable back in.
Sent from my SM-N900V using Tapatalk
M35A2-AZ
436
Tonopah, AZ
A quick fix is to rap some safety wire around the stop on the cable then around shutoff, that way you can push it back after you shut it down.
155mm
Chief and Indian
497
Guymon, OK
If you are having solenoid issues, verify that it is 'sucking in' all the way also, or you may begin to have starting/run issues due to the push rod not retracting and letting the fuel cutoff open fully.
simp5782
Feo, Fuerte y Formal
9,509
Mason, TN
Unscrew the combat mode knob on the front of the solenoid. If it spins freely get vise grips on the stud itself. And turn it out. Itll.allow you to shut it off with the switch.
Sent from my SM-G935P using Tapatalk
