MAJOR
- 0
- 6
- CAMBRIDGE N.Y.
When raising hoe from travel position, had to use the control lever to Lower. ++ Could not lower with either lower or raise control ???
He has made a bunch of posts on aWhat type machine are you working on? Also pics help alot. i am no expert on some machines but do have many years doing hydraulic work. More info like what type machine, exact issue would help someone who knows alot about it. Good luck
Okay, assuming that this is about a SEE, yes, you have to use the control lever to raise and lower the backhoe. The lever by the hose reel, that is.When raising hoe from travel position, had to use the control lever to Lower. ++ Could not lower with either lower or raise control ???
I sure hope that you're referring to your backhoe there, peakbagger.Mine really doesn't like to raise especially when its been run for awhile and the fluid is hot. It eventually makes it back but its not happy about it.
