- 1,199
- 454
- 83
- Spartanburg,SC
I'm jealous! Looks like fun!
It's amazing that you found the broken schrader valve and cap! Gotta love working CTIS to air back up. How far did you drive on the flat tire?
Sure, here you go KC HiLites , GRAVITY® LED 7" HEADLIGHT PAIR PACK SYSTEM - DOT, direct bolt in
Seth
Will be interesting to see how these do in Snowy areas. Do they have heaters in them to melt snow?Sure, here you go KC HiLites , GRAVITY® LED 7" HEADLIGHT PAIR PACK SYSTEM - DOT, direct bolt in
Seth
Slick if it could replace a plow blade, but I guess that technology isn't here quite yet.dont think they have heaters, we have a 6 foot light bar that will melt snow, just dont have it installed yet
Seth
Slick if it could replace a plow blade, but I guess that technology isn't here quite yet.![]()
I finally got underneath to check these bolts today. Very interesting, they are installed backwards and all I’m seeing is threads. The hex head is not accessible. Either someone put them in backwards or this is a TM revision to keep them from loosening.Better check your fly wheel bolts, ours were not tighthttps://youtu.be/jnKev0FuLCc
maybe put some locktight on the exposed threads to keep them from backing out?I finally got underneath to check these bolts today. Very interesting, they are installed backwards and all I’m seeing is threads. The hex head is not accessible. Either someone put them in backwards or this is a TM revision to keep them from loosening...posted pic here....
