Bravojmc
- 5
- 0
- Palisade, Colorado
Hi guys, so I installed a 24v to 12v converter and it works great. It's making 12.3v from 25v. Now to the problem... I installed a Aux fuse panel and I have 12.3v at the main post into the fuse panel. I check the voltage on the fuse output and perfect 12.3v. Now the issue. If I pull the fuse I'm still getting 10.3v.... if I pull the fuse IMO I should have zero volts right...? Also need to tell you I don't have any accessories hooked up to the panel yet. As you guys can see the panel has leds that light up when the connection is broke. When I pull the fuse the leds don't light.. is this from me not having an accessory connected ?
Here is a picture.
Also when I check ohms with fuse in I have a connection. With no fuse no connection. Sorry my electrical terms are for the birds...
Here is a picture.
