- 4,467
- 2,398
- East of Edmond, Oklahoma
AKA "Gin Poles".
Ya'll have enough to put on you own!
Hey Ken, my truck needs a paint job. Will ya'll spray a color other than green?Yup put tan one right in the middle and have a military oreo. Lol
Mike, I wouldn't trust Ken to paint our tans trucks. I bet there would be a paint malfunction and come out green.Hey Ken, my truck needs a paint job. Will ya'll spray a color other than green?
Sent from my SM-G900V using Tapatalk
Tan probably hates you too.Yup I HATE tan. Lol
About once a month I go around with a bottle of soapy water and check the truck for air leaks. I found a couple this time around.
1. The #2 tank drain cock (yes, I said it) had a slight leak no matter how tightly it was closed.
I replaced all 4 with a new style I ran across a couple months back. These look to have been used on MRAPs and FMTVs according to Parttarget. NSN 4820-01-363-2117
2. The valve on the the transfer case, to auto engage the front axle in low, was leaking slightly around the shaft.
I disabled the valve a couple years ago. I'll eliminate it, and all the extra lines, completely after I get a couple of fittings.
I've never really checked inside the cab but I did this time since the T-case valve was leaking. The T-case valve is the same one used on the parking brake handle. Sure enough, the parking brake valve had a slight leak around the shaft too.
While I had it all apart I decided to replace everything down there with new parts. I replaced the handle, valve, switch, bracket and cable.
Daaaaang, no matter how long I watch, they don't stop jumping!PrEEEEEEseeeeent Haw !!!!! Boioioiong ! My hood'd be up to. Congratulations !
