M886 Ambulance Heater Question
chillydog
Scranton, Pa.
Hi guys! I have a few questions concerning the fuel fired heater in the rear patient compartment, of the Dodge M886 ambulance:
1. Looking at photos, there is a top flange, and bottom flange where the exhaust pipe goes through the floor. Looks like there is a 3" ring welded to the top flange, to protect the floor from heat. In the center of the top flange, is an exhaust pipe, welded in- is this pipe opened up to receive the heater unit's pipe, in a kind of tight slip fit? (keeping fumes out)
2. The pipe that's welded to the top flange, where it exits the vehicle-- a flex pipe fits over this pipe. Is the flex pipe tack welded on, or clamped?
3. What's everything made of- Stainless, aluminum, or plain steel?
I'm trying to make this system up, any help and knowledge is appreciated! Thanks!
chillydog
Scranton, Pa.
M886 Ambulance heater
Hey chillydog,
Did you get the heater up and running? I have at least one complete unit.........
Hey! Thanks for your reply. I'm very close to getting it working. I picked up a NOS heater from Saturn Surplus, problem was, you also need the install kit to mount it. A local friend has a M892, kind of sad derelict that will never run again, and I got measurements from it. Had to make the mounting legs, and hardest part, ( still working on it) the exhaust pipe and heat shield assembly. You have one? Hmmmm..
Thanks, Paul;
41WC18
Warren, ME
Paul,
I'll check to see exactly what I have........ jmo, make SURE you install a Carbon Monoxide detector for that box! :tigger:
