Dock Rocker
- 72
- 28
- Jackson ms
Ok. We have our first hurdle. I have a no flow situation on the fuel system.
It appeared that I was not getting any fuel to the IP. I backtracked and it does not appear that I am getting any fuel flow at all.
Here is what I have checked so far. I have been using the TM to get as far as I have but I have hit the end of the road. Any help would be appreciated.
I installed the tank and I have confirmed that the pickup tube is in the number 1 hole (closest to the fuel filler hole). The routing of the hoses is as it should be per the TM. I blew the lines out but pulled one at a time and reinstalled them before moving to the next hose.
When I turn the switch to the Auxiliary pump I hear it kick on. When I go to prime/run I get no noise from either the #1 or #2 fuel pump. Also no fuel flow on the outlet side of either pump.
I tested the wiring and in the auxiliary position the auxiliary pump has power. It kills the power to the auxiliary when I go to prime / run, so that's working.
When I go to prime / run there is power going to the switch at the fuel pumps. See pic below
I cannot confirm that there is power coming out of the box in the pic and to the pump. I am not sure how that unplugs and I don't want to damage it. There isn't a plug going into the fuel pump to check for power there. The wire goes directly into the pump with no connector.
This unit was confirmed running before I broke it down to clean the fuel system.
I am going to download a few more TM's and see what I find.
![](http://uploads.tapatalk-cdn.com/20170705/794693e55c08fba466a544a7a8d860cf.jpg)
