M923A2 BMY 1988 8.3L 6CTA Cummins Belt Tensioner and alternator pulley
wilkusmcrecon
Meadow Lakes Alaska
Been trying to get my hands on a Belt tensioner and Alternator Pulley for my 1988 BMY M923A2 8.3L 6cta.
Can you provide me a NAPA part number or a place that can provide the parts needed.
First pulley provided was to small.
would appreciate any help in locating these parts. Need to get her up and running.
Chris W
BKubu
1,241
Gaithersburg, MD
The alternator pully is a tough one to find. I got one from John Murray from TNJ Murray in Dover, DE. When I got one (several years ago), John told me that he only had one more. Perhaps, he got more or maybe he never sold that one. It is worth a try.
simp5782
Feo, Fuerte y Formal
9,509
Mason, TN
Belt tensioner is in the spreadsheet. 38513
Sent from my SM-G935P using Tapatalk
Tinstar
2,607
East of Edmond, Oklahoma
Recommend you ditch the stock alternator and upgrade.
The original ones are notorious for frying and taking out other electrical components with it.
Found out all that the hard and expensive way.
Belt tensioner is easy to find. On eBay also.
Go OEM or Gates makes a good one. Part number already mentioned.
I also have original pulley if your source doesn't pan out.
Edit...pulley sold
wilkusmcrecon
Meadow Lakes Alaska
Had no luck with first two. All were two small and both had a grove that fit the alternator pulley shaft. Mine requires no grove the shaft is tapered out a little wider past the bolt. Let me know if you are still interested in parting with your pulley. PM the requirements and we can it a go.
Chris Wilkinson
74M35A2
340
Livonia, MI
Pulley interface is one of several weak points of the stock alternator. Once warbled out, this already weak interface becomes even worse, never to get better. This keyed joint is not commonly utilized anymore, for good reason, it doesn't work well long term through various harmonics.
Upgrading to a civilian unit completely resolves this issue due to a closer tolerance fit with no keyway and high torque nut to pinch the pulley against a shouldered rotor shaft end, in addition to the over-volt issue on M939's when shut down in "wrong" order, improved threaded connections, better cooling, etc....
It is a great way to put this behind you, no matter where you get it from. Many members here have made the change, and I don't recall a single one regretting it. Most say they should have done it sooner, and many order several across their fleet.
It can be disheartening to remove something we think is best designed to be there and install one that looks like it came from a Chevy pickup, but the improved operability becomes apparent almost immediately. I recommend it for nearly all applications expect if being judged in shows for authenticity.
