- 7
- 0
- 1
- Cottageville, SC
Hello,
I'm new to the forums, and pretty new to big green steel. What we have here is a 1953 IHC M62 Wrecker, upgraded to an "A2" equivalent standard at some point. From what I can figure out so far, it was in the Minnesota NG until 04ish, then to a State agency, where I bought it from.
Overall, its in good shape, but has unfortunately and obviously been abused at some point (more on that later). It has the mounting points for "H" frame floodlights, with no lights on the shipper. The transfer case / winch levers are reversed, and it has the boom leg stowage on the sides
There is some rust on the inside of the fenders and the wrecker bed but for a '53 that spent a lot of time in MN its not bad at all.
The multifuel starts with a little effort (about 10-15 seconds of cranking), but it has a few issues. The power steering is INOP, I haven't done any troubleshooting on that yet. The air system won't pressurize, after connecting to my M35 the clutch roto chamber is blowing air straight through, even when the lever on the wrecker bed is off. The boom moves through the full range up, down, left, and right, and extend, but won't retract past about 13 feet.
The boom seems to have been badly overloaded at some point, there are pushed-out bends on the back of the shipper, and the underside is creased in. The boom pulley end is cut from cable rub. When retracting, it seems to bind against the shipper near the boom pulley end.
Overall, its a great truck, I'm planning to start with the battery compartment, then air system and power steering, I'm not sure what to do about the boom and shipper, I think they both will probably need to be replaced.
This is going to be a long term project, right now its going to be used for light work around the property. Eventually, I'm thinking its destiny will be back in early OD green.
Over the last few months, SS has been an absolute wealth of information, thanks to all who have posted and added!
There are some questions I'm hoping someone can help with:
1. I have the copy of Army Motors 137 and have scoured this site and many others searching for bits of M62 history. Does anyone know of any hidden resources that may help discover more about the trucks history?
2. Any ideas about the boom and shipper?
3. There are a couple of posts about replacing the roto-chamber with with a standard brake chamber, but with a single side clamp. Every one I've seen has two sided clamps, does anyone have a P/N for one with a single side clamp?
Thanks,
--Dan
Thanks,
--Dan
