dutchguy
- 1
- 8
- Lawton, Michigan
A while back I'm having trouble getting trans into 3rd gear. Then one day, I feel a "clunk" going into 3rd, after which 3rd gear is unsynchronized. All other gears operate fine. I can also get into 3rd at a standing stop. Took the top off the trans this week, expecting to see the 2nd/3rd synchro messed up. Everything looked great visually. Then, after going to be for the night, I realize that I had been moving 3rd gear back and forth on the mainshaft a good half inch. Hmmm. So, removed the mainshaft, and the 5th gear thrust washer is there, but the retaining ring is gone. I assume the "clunk" was the ring letting loose. Then, I suppose the synchro ring couldn't engage 3rd gear because it slid down the shaft.
Question, is the ring letting go a common thing with the Spicer trans? I plan on just ordering a new one, and that everything will be OK.
Lastly, the TM states to press 3rd gear and the 5th gear sleeve onto the mainshaft, but the fit specs in the TM indicate a loose fit. My gear and sleeve slide right on without pressing. Is this normal?
