I pulled the old original air dryer off the M1081 this morning to see what it looked like inside as far as clean/wet. I can't post pictures from home, but the base of the original unit was full of tan mud....emulsified water & oil. No way was this thing doing any air drying, should have listened to you guys last year about replacing this. All pictures of replacement installations show none of the large original bracket that is removed & replaced by the Haldex plate. Is that attachment bracket just thrown away with no issues? I will continue with the tear down when the rain stops.
Okay, Schooled again; the large bracket that held the original air dryer works with that dryer, but when you go to install the new Haldex unit, the air inlet elbow bumps into the side of the bracket bolted to the frame. After seeing the problem, it started to rain again & back in the shop. So I guess I am set in my ways & don't want to remove the bracket. The universal plate had enough room to mill out 7/16" in the elongated bolt holes to set it further out away from the original bracket. When that move proved to work, two more holes were opened up so all 4 bolt holes to be used. The outlet had to be moved from its original position to where the hoses would connect up with nothing rubbing on the frame; same with the inlet hose. The control hose is too short now due to the connection port has rotated 90 degrees from the original attachment, so I will have to hard pipe it with 1/4" SS pipe fittings to where the original plastic hose can connect. Now my install is unique to this truck. Pictures to follow when finished!
![LMTV Air Dryer Base.jpg LMTV Air Dryer Base.jpg](https://www.steelsoldiers.com/data/attachments/473/473901-50f1e0aca9bc1b5b5fc1a9125feb725d.jpg)
Here is the inside of the air dryer base.
