Scooteerr
- 0
- 16
- Toney, Alabama
The gimp has his ways....Where does Gimpy get those avatars?![]()
I had to look it up!!! forget the avatars.............how does he know these things!!!Nah, your my minger.
Google image search required!
Do you have any pictures of yours? Maybe we can help.
Also, it's a bit of a read, but worth it:
https://www.steelsoldiers.com/showthread.php?8460-Front-axle-seals-and-boots-stepXstep
If you don't know when it was last done, you probably should service all the axle ends so you can inspect the condition of the brake pads, drum, bearings, spindle, bushings, brake/wheel cylinders, axles/u-joints, and replace oil seals.
I had never serviced an axle before, let alone 2.5 ton Rockwells. Between the Technical Manual for the process and the above thread with help from folks here, I managed.
With the boot you have to make sure it is oriented correctly for the turning of the knuckle. Also you have to ensure the position of the clamp's screw is in a position that won't damage the boot when the ends are turned. Post #23 of the above thread covers that:
https://www.steelsoldiers.com/showt...-boots-stepXstep&p=75932&viewfull=1#post75932
