Jericho
- 70
- 48
- Landaff NH
Got the same answer about shipments from / into NV , don't know why
I am going to add convoy lights to mine but i want to do electric telescopic poles so when i am not hauling an oversized load or empty they would sit below the cab top.I installed a factory convoy light set on my M923. Now she is ready for the Weare, NH convoy. They look and work good. They are a little tall and they are in the stowed position! They could go up another foot or two. I know I would hit every tree branch if I put them up. I had to remove the spare tire as I have 1400 x 20 on her and her bed is still in the original position. The 1400 fit in there but just barely and had to remove the intake to get in and out. Spare will be in the bed for now.
Hey coastie, what is that multi-segment LED for that you have under the front diff control?I installed a factory convoy light set on my M923. Now she is ready for the Weare, NH convoy. They look and work good. They are a little tall and they are in the stowed position! They could go up another foot or two. I know I would hit every tree branch if I put them up. I had to remove the spare tire as I have 1400 x 20 on her and her bed is still in the original position. The 1400 fit in there but just barely and had to remove the intake to get in and out. Spare will be in the bed for now.
I made custom mounts for mine and was able to mount them a foot+ lower. That way I don't rake the top of the shop door when I'm pulling in...I installed a factory convoy light set on my M923. Now she is ready for the Weare, NH convoy. They look and work good. They are a little tall and they are in the stowed position! They could go up another foot or two. I know I would hit every tree branch if I put them up. I had to remove the spare tire as I have 1400 x 20 on her and her bed is still in the original position. The 1400 fit in there but just barely and had to remove the intake to get in and out. Spare will be in the bed for now.
Ordered and received twelve 3/8" thick x 5.5" OD steel discs with 1/2" holes in the center. I'm going to install these over the end of each torque rod (dog bone) end to keep it in place if it slips off again, drill and tap 1/2" bolt.
Yes, that is the length of troop seats in the dump truck M929 and M817 and also the side boards. It might be a couple inches longer for the wood. Do you need an exact measure?TobyS what is the length on the sideboards for the dump? I recently picked up some troop seats that measure about 10'1" and was trying to figure out what they were for. Thank you. The deuce and rear on the M923's are about 12'2".
