- 293
- 29
- 28
- Odessa/Texas
I filled it up with oil, I couldn't source any John Deere Break in oil locally. I used Rotella T 10W-30 figure Ill use this since I had it on hand. I adjusted the valve last night, decided I would see if I had compression by turning fly wheel by hand. Turns out I messed up the valve job, there is quite a leak on the exhaust side. Since I have the studs for exhaust removed I can create a seal with the palm of my hand. When I place my hand over it I get a good seal good enough to make a squeaking noise from the air escaping under my hand.
So it apparent I didn't do a good enough job on valves, the valve grinding compound that I used is 120 grit. I think that was the mistake and using lead off of pencil to check the seal of valves. I see that 440 grit is need for finish. I am just happy that I caught this before placing it back into unit and running it. I plan to pull head and regrind valves starting with course then fine grit then check seals.
When I do break this unit in I'm not worried about saving fuel by running it at the minimum hours. I'll probably run it for 5 hrs then change oil/filter, 10 hrs change oil/filter, then normal intervals. I wont consider this set mission ready till I put 50 hours on it after this tear down, just my personal opinion. I don't want to be worried about unit when its running, I swear I'm paranoid when I have a gen set running that is new to me.
