- 1,450
- 126
- 63
- Gray, GA
On to the water pump...
So apparently this is the only picture I have of the water pump. This is the water pump cavity if you've never seen it. Use a new copper seal and antisieze around the surfaces. Moving on...
Old thermostat. May as well replace it while the coolant is drained.
All cleaned up with new inner seal installed.
New thermostat properly fitted and tested on the stove.
New long overflow hose from tank to radiator...just because I had one.
New coolant, SCA additive and filter. Couldn't find my test strips and had to buy more. Par for course...again. I also ran an inspection camera through the radiator while it was empty. I was prepared to put in a new one at this point if it was in bad shape. Very happy that this one looked perfect inside. No scale or build-up anywhere.
All new belts.
Replaced the heater hoses.
And added the hood handle reinforcement tabs I forgot to put on when I replaced the hood.
Oil and filter change.
New driver side axle boot.
And a shakedown run to the Dairy Queen.
All new belts.
