MEP-803A frequency cable
Light in the Dark
5,508
MA
If the plastic is still on them, then they have never had acid in them.
Thats great to know... free batteries that I thought were dead! One makes no noise when moving, the other sloshes a bit. I would have assumed there was no liquid in them if the plastic was retained. Thoughts?
Guyfang
23,030
Burgkunstadt, Germany
What does asid react to? Baking soda? If so, take a few drops and put it on a small pile of baking soda. See what it does. If it doesn't react, then maybe its water? Normal, when they come new, the cells are covered with a yellow, (I think) plastic to keep out moisture and dirt. Only way to find out is try it. Was the set dirty when you got it? Or look like someone had pressure washed it?
Light in the Dark
5,508
MA
It looks like water in one... didnt realize those caps spin off till now. I will have to give it the baking soda test. Water won't ruin the plates inside of a battery like this, if its been sitting that way for god knows how long?
boatman69
Cape Coral, Fl
It's definitely not good oxygen in air or in water isn't not good for the plates.
FWIW - DRY-CHARGED: The battery is built, charged, washed and dried, sealed, and shipped without electrolyte. It can be stored for up to 18 months. When put into use, electrolyte and charging are required. Batteries of this type have a long shelf life.
Acid is cheap I'd go for it.
Light in the Dark
5,508
MA
I am not even sure which machine I pulled these out of... maybe one of the 802As I have. I opened the top one the sloshy one yesterday, and it had no odor (and what appeared to be a slight oil sheen)... so I am thinking that it is water. Need to figure out a container to dump it into, for testing purposes (as I have no way to pipette out some for testing).
Guyfang
23,030
LID, (Light in the Dark)
Put a few drops of the liquid into a spoonful of Baking soda. If it bubbles, its acid. If it doesn't, its water and just dump it. I always use plastic containers for acid. For storage, use ONLY plastic. A glass container can break. Believe me, not even funny!
The straw trick sounds good.
Daybreak
2 Star Admiral
760
Va
Howdy,
The 2HN battery was the older spec'd battery for the MEP-802A, and they have updated that to the Optima 51R
