Can't figure out why it won't start
anjay22
Seguin, Texas
I have been working on my duece for a while and it won't start. My injector pump at the top moves up and down and fluid comes out when the pump is on and when the plug is removed from the side, fluid comes out as well when the fuel is turned on. I have fuel but nothing is getting to the hydraulic head. I took the lines off to even see if fluid is moving, and nothing.
Sent from my XT1565 using Tapatalk
rustystud
3,372
Woodinville, Washington
So your saying that with the center plug on the Hydraulic Head removed, the valve is moving up and down. Is it spinning too ?
You also took out the twelve point plug on the side of the Hydraulic Head, and fuel came out under pressure. Correct ?
But you have no fuel coming out the injection lines. Then I would say your fuel rod is stuck in the off position.
There are a "bazillion" threads on fixing that here.
anjay22
Seguin, Texas
That is correct. The valve does move up and down and I did take out the twelve point plug and fluid came out. I know this is redundant because I too have read this over and over again. I have been doing tons of research in regards to this, but I am the guy that is the epitome to every example. I am just so frustrated because I want to fix my truck so I can get to Houston to help out. I will check the fuel rod and give it a go. Thank you guys and I will keep you posted.
Davidwyby
244
CA
Plunger needs to move about 3/8". With the button off, it will move, but not enough.
anjay22
Seguin, Texas
My question is, if the fuel rod is stuck, then how does that relate to the fuel shutoff when it is fully engaged inside the cab and is functional at 5 and 7 o'clock. Is the rod behind that simply not moving as intended?
gimpyrobb
dumpsterlandingfromorbit!
27,787
778
Cincy Ohio
Yes, when the "cap" over the fuel shut off rod moves, there IS NOT positive engagement and the rod might not move. I'd pull the cap and move the shut off rod with your fingers.
If there is any resistance to movement, that is not good.
anjay22
Seguin, Texas
Well, I pulled out the shutoff rod and cleaned off both and the "tit" by taking it out. It kind of reminded me of a LIFE game piece. I put it all back together a and still nothing. I watched for fuel to come out if the hh and it's dry. On the other hand I pulled the center plug on the hh and it moves up and down and the 12 point on the side has fuel that comes out with the plug removed. I am still lost. I am done for the day, but I think I need to mess with the fuel shutoff rod again. It does feel tighter when the fuel shutoff is pulled
anjay22
Seguin, Texas
Oh, and fuel does come out of the center plug when the battery switch is on...
mmeridith
Apopka, FL
Pull the hydraulic head & check the shaft... mine died last month and found the problem was a damaged hh shaft. Would not start without gas or SF, only run 2000 rpm & higher & would not idle. I imported some chicom heads and it runs fine now. Still have a few left if anyone is looking, comes with button & clip. PM for details.
Sent from my SM-G950U using Tapatalk
anjay22
Seguin, Texas
Well my big issue is this, my truck was running wonderfully until I had to work non stop and then attempted to start her up 6 months later with no luck
anjay22
Seguin, Texas
Yeah, it's no good. The clip and the button was sitting on the bottom when I pulled the hh. One end on the clip broke off
