- 2,488
- 1,900
- Efland, NC
That should do it. ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Couldn't you use your house system's ground?Good call - It's just temporary for now.
Once I hook up to the house I will disconnect the ground rod and remove the ground bar connecting ground and neutral. The ground rod is there for when I run the generator unhooked from the house. I use the temporary ground rod when I run the load bank which I am currently working on.Couldn't you use your house system's ground?
I've never used it before but it looks like it is gonna work well. Glad to see a fellow buckeye on here....That Lexal is some tenacious stuff!
It is good stuff. Ive gone through over a dozen tubes of that stuff sealing up around the house. Expensive but worth the money.I've never used it before but it looks like it is gonna work well. Glad to see a fellow buckeye on here....
