Front prop shaft replacement
Pointman0853
14
Gardnerville, NV
So I detected excessive spline play in the front prop shaft... What to do? A local shop specializing in drive line repair (and a Spicer auth. dealer) quoted me $575.00 to repair.
Thanks to Suprman for the referral to Eastern Supply. Bought a new one for $475.00 and it appears to have much larger splines than the stock one (photo attached) stock is on the left, replacement on the right.
Pointman
Awesomeness
1,523
Orlando, FL
Do you happen to have their internal part number for that shaft? I can't seem to find it on their site (the search function returns nothing for searches like "driveshaft" and "fmtv shaft", even though I can obviously see there are items with those keywords in them).
Pointman0853
14
Gardnerville, NV
NSN 2520-01-545-0390
My contact at Eastern Surplus/Flight Source was Joshua Fulkroad.
717-896-7570 Good Luck with your search..
Pointmam
Pointman0853
14
Gardnerville, NV
The manual shows #483-49-050-145 for the front, #483-49-050-433 for the rear. Hope this helps you!
Pointman
Awesomeness
1,523
Orlando, FL
I called them (twice to make sure), and they had no idea what I was talking about. They said the best they could do was $1000 for a new one, or they had a truck they could pull a working one off of for less. A very strange conversation.
Pointman0853
14
Gardnerville, NV
I had an offer from a local drive line shop (and a Spicer authorized dealer) to rebuild my old one for $525.00. I found the heavier duty unit and jumped on it.
I may need to rebuild when the rear goes..
Pointman
Awesomeness
1,523
Orlando, FL
Yeah, they're going to rebuild mine and replace the u-joints for $475. That's why when I saw your post the same day I was like "****, might as well buy a new one instead."
Pointman
