looking for fmtv
jmmay82
Chicago IL
couple questions
looking for a single axle to mount a hydroseeder on which requires a 32k Chassis and lots of highway. to get from job to job . then when on site. pretty extreme off road conditions. any help to point me down the right road or model to investigate would be greatly appreciated. thanks.
Jason
gvw. is it so low because of not having rear duels and auto inflate? if so can auto inflate. be removed and 22.5 rims and tires be installed ?
do any versions come with part time 4x4 ? or are they all full time 4x4 ? is the a lot for part time 4x4 to be installed
what is highway speed?
NATCAD
50
Port Huron Michigan
couple questions
Jason
Jason how much does the hydro-seeder weigh?
You can see the technical manuals here:
snowtrac nome
137
western alaska
the weight limitations on the lmtv are de rated for off road. duals wont help much, and will detract for off road use you would be better served with a 5 ton model and maybe a tractor just remove the trailer towing components I have worked on hydro seeders they are tall and not likely a good mix fro an fmtv. you might look into mounting the hydro seeder to a trailer and usint a truck to tow it or maybe even a small loader to move it in off road conditions.
Awesomeness
1,513
Orlando, FL
That would probably be pushing beyond the limits of an LMTV (single rear axle), and maybe just inbounds for an MTV (6x6) if you remove the bed.
Top speed is around 50-55MPH.
DiverDarrell
22
Port orchard, WA
High center of gravity, over loaded weight capacity. Liquid load with free surface affect, lots of highway. Not the best choice for your application. Even with the 6x6 the high cg liquid load would be sketchy. I'd do it with a 6x6 but would want a custom tank that saddled the frame. They limit the 4x4 things to 500gal fuel cells for a reason and shifted to a lower fatter tank to do it.
