steelydan
- 4
- 8
- Somewhere, NH
This spring, I won a trailer'd MEP-803A via GovPlanet. I had to head down to Chambersburg, PA to pick it up.
I thought I'd write up some quick tips I learned - maybe it'll help someone else.
Things I did before leaving:
Lessons Learned:
Here are some pics with explanations.
Trailer hook-up - the chains didn't reach my truck's hook points, so I hooked them to the pintle hook mount, and zip-tied them so they wouldn't easily rattle off. As folks have mentioned in the comments below, the chains need to be anchored to a point on the truck in case the hook, riser or pin fail. At least I knew to cross the chains.
Same for the safety wire, it needs to be connected to a better structural point than the safety pin bracket (I had already untied it, then realized I wanted to take pictures, but was too lazy to property reconnect it before taking these pics).
I attached the HF tail lights on the rear bumper, right in front of the trailer's lights so it would look like they belonged there. I zip-tied and 550-corded each light to the bumper because I read that the magnets weren't strong enough to keep them attached:
I duct taped the wires to the trailer so they wouldn't get caught on anything, get ripped off, or frayed from rubbing:
Every door got duct-taped so they wouldn't fly open while I was driving. I didn't want to have to stop for anything if I could avoid it:
Even though I tested the HF LED lights in the store parking lot, and at my house before I left for the pickup, one of them decided to fail when I hooked them up at the pick up. Shesh.. After doing some troubleshooting, it turns out that the terminal had a loose connection and if I pulled up on it while it was plugged into my truck, the light would work. So, I grabbed a rock from the parking lot, wedged it between the terminal and the wire harness cap, and duct-taped the whole thing together (picture shows it after I removed the tape). Total McGiver action, but it worked!
Well, I hope this helps someone who's never towed anything before (like me) and is planning a trip to recover their won generator. Let me know if there's anything I could've done better for next time!
- I printed out the generator listing on GP, including each photo. That way I could dispute the condition of the generator if I got there and something was wrong.
- I bought a pintle hook rated for the genset and trailer and a pintle hook mount that would get the hook high enough that the trailer would tow level behind my truck. I didn't tighten down the nuts till I was on-site and I was sure the hight was correct for my truck and the trailer. Here are links to them both of you're interested:
https://www.zoro.com/buyers-products...38/i/G3699561/
https://www.zoro.com/buyers-products...12/i/G7131047/ - I bought a spare tire on CraigsList. In the generator's listing photos, the trailer tires looked good - no cracks and fully aired, but I wanted to be prepared in case something happened while dragging it home.
- I made sure I had sockets that fit the lugs on the tires.
- I bought the LED light kit from Harbor Freight. I figured if one of the LEDs went out, I'd still have some working vs having a bulb go out in the incandescent version.
- Before I left the HF parking lot, I hooked up the lights and tested them with directionals and braking. It would suck to get to the pickup spot only to realize that my new light kit didn't work!
- Also from HF, I bought their 4-in-1 Jump Starter with compressor. I figured I could use this to air up the trailer tires if they were low. I made sure it was fully charged before I left.
- I took a whole bunch of tools I thought I may need. Duct tape, screw drivers, pliers, hammer, crow bar, etc.
- I packed sandwiches, snacks and water in a cooler I kept on the passenger seat so I could reduce the number of stops.
- I printed the map from Google and highlighted the route - that was in case my GPS went down. I planned stops for food/fuel/relief. I tried to time my leaving so I'd be going through any cities during off rush-hour.
- I called the pick up site to confirm my pickup day and time. Good thing I did, because they had limited days and hours available for pickups.
- I booked a hotel reservation within 5 miles of the pickup site. My plan was to drive down on Sunday, get a good night's sleep and get to the pickup spot early. I'd heard horror stories of folks waiting a long time to hook up their generators and some even got different ones than the aution showed (this seems to be common for GovLiquidation, not GovPlanet, so I used GP.
Lessons Learned:
- Use the big-rig fuel stops (I have a diesel pickup truck) since they're built for long vehicles. It's much easier than trying to snake your way through the fuel stops made for smaller vehicles. But those diesel fuel pump nozzles are bigger than the ones you'd find in the 'regular vehicle' fuel lanes, so I had to pump really slowly so it wouldn't spill all over the place.
- Avoid cities like NYC. It's better to go around even if it takes a bit more time. It's less aggrevating and you can avoid expensive tolls.
- Driving 65 - 70MPH is fine with this trailer and tires if they're in good condition.
- I hate surge breaks. They definately take some getting used to.
- Drive reasonably. At one point, I had a state trooper pull up behind me to take a look. I tapped the brakes to show him I had working tail lights. He then pulled out and sped past me.
- Do more research on the trailer before leaving. If I did, I'd have known that the chains are too short to reach an anchor point on my truck, and I'd have prepared for that.
