corelokt
- 2
- 16
- Duffield, VA. (East of nowhere).
With the air filter and CDR fixed, it's not that bad.
You said you're burning a pint of oil per 3 miles.
Driving from New York to Virginia pulling a 5 ton trailer.
Thats about 500 miles.
Divided by 3 equals 166 pints of oil burnt.
2 pints to a quart thats 83 quarts.
4 quarts a gallon thats 20.8 gallons of engine oil burnt to make Virginia.
Well, at least you'll save money on diesel fuel by burning that much out of the crankcase.
You'll be a quart low every 6-10 minutes.
Probably best to get one of those hand pumps and duct tape the line right into the crank case fill and the 20 gallon oil containers in the cab next to you.
That way you can pump oil into the engine as you drive.
Good Luck.
Actually known people to do things just as crazy to make it home;
